disable dns cache
disable dns cache {{vlan} vlan_name | {vr} vr_name}
Description
Disables the Domain Name System (DNS) cache on a virtual router (VR) or VLAN.
Syntax Description
dns Domain name system.
cache Specifies disabling the DNS cache.
vlan Specifies disabling DNS cache on a VLAN.
vlan_name Specifies the VLAN name.
vr Specifies disabling DNS cache on a VR.
vr_name Specifies the VR name. If not specified, the VR of the current command context is used.
Default
If no VR name is specified, the VR of the current command context is used.
Usage Guidelines
To view the DNS cache configuration, use the command show dns cache configuration {{vlan} vlan_name | {vr} vr_name}
The following example disables DNS cache on VLAN "VLAN1":
# disable dns cache vlan VLAN1
This command was first available in ExtremeXOS 30.3.
Platform Availability
